Re: Should I Line Bore?
Posted by Shovelman on January 09, 2003 at 05:59:53 from (24.151.89.245):
In Reply to: Should I Line Bore? posted by Jeff_MI on January 08, 2003 at 19:08:55:
Jeff, I agree with Randy. Chances are, the new caps will not match the block. You will most likely have to line-bore. The machinist will cut some material from each leg of the bearing caps, making the diameter of the bores smaller. Then the bores will be re-cut to the original (factory) I.D., and everything will be back in line and back to original specification. A bit of advice: Carefully inspect every part for damage before you commit to any large expense - line boring, etc. If the main bearing caps were broken, there had to be tremendous stresses put on the block, crank, rods and other components from the ice. There may be other damage that you cannot detect by eye. I would have your jobber check the crank for damage and straightness. Also, check the rods for alignment and twist before you reuse them. Carefully check the block and head for damage. Replace the main bearing cap bolts and maybe the rod bolts as well, if you suspect they were stretched or stressed. Good luck! Scott
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
