1947 farmall h
Posted by wayne mosley on March 28, 2009 at 21:33:27 from (72.177.182.95):
restoring farmall H tractor. New wiring harness 6 volt system. Regulator mounted in front of steering post. Does the juntion block inside dash panel need to be insulated or do you attach it to the metal panel uninsulated with the 3 wires connected together.Tractor is positive ground.Lights do not come on but starter engages.
or will this problem correct itself once tractor is started and generator polerized?
