Re: More Head Bolt Vs. Studs
Posted by Bill B on January 13, 2003 at 04:48:20 from (209.113.233.74):
In Reply to: More Head Bolt Vs. Studs posted by Steve Belcher on January 12, 2003 at 17:36:20:
Good information. It should be also noted that studs usually have coarse threads where they go into the block, and fine threads for the nut. Cast iron needs the coarse threads, as it is weaker than steel. But fine threads give a more precise torque rating when tightening, as they are "geared lower". It is my opinion that engines that are made with bolts are usually done to save money on the assembly line, not to make a better product.
Post A Followup
: Re: Re: More Head Bolt Vs. Studs
