Re: Upper Bolster Revisited
Posted by john on January 13, 2003 at 15:53:11 from (192.233.162.129):
In Reply to: Upper Bolster Revisited posted by Kelly C on January 12, 2003 at 17:28:57:
I replaced the thrust bearing on my H. My bushings were ok. I have a little (not much ) clearance between the sector and bolster housing. I think that you are supose to have a slight clearance otherwise the sector would wear into the bolster. My problem was that my upper bolster pivot shaft was aftermarket, when I put the sector gear on it then tightened up the nut, the cotter pin wouldn't go in the nut grooves, so I put a washer between the nut and sector.
Post A Followup
: Re: Re: Upper Bolster Revisited
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
