Re: Ice in my transmission?????
Posted by Russ Smart on January 14, 2003 at 16:29:34 from (208.5.140.74):
In Reply to: Ice in my transmission????? posted by Andy in MN on January 13, 2003 at 17:52:15:
It sounds like you are in two gears at once, because the square corners are worn off the shifter. pull the shift rod out the top and make sure all the slides are lined up in the center. At least that is the way I remember doing it 35 years ago on our M, whenever I tried to shift to fast from 4'th to 5'th!
Post A Followup
: Re: Re: Ice in my transmission?????
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
