Re: New felt Seal, Tight engine on Super A
Posted by JARROD on January 15, 2003 at 07:21:04 from (24.172.74.8):
In Reply to: New felt Seal, Tight engine on Super A posted by Brian on January 14, 2003 at 17:45:33:
BRIAN I HAD THE SAME PROBLEM ON A 130 FARMALL.
I HAD A SLIGHT CLEARENCE PROBLEM ON THE CENTER
MAIN BEARING.I TOOK THE ENGINE TO MY LOCAL NAPA
MACHINE SHOP TO CORRECT THE PROBLEM.I HAVE NOT A
CLUE IS TO WHAT THEY DID BUT IT FIXED IT.
GOT IT HOME AN INSTALLED THE REAR SEAL HAD THE
PROBLEM OF NOT BEING TO TURN THE ENGINE WITH THE
HAND CRANK.I WENT AHEAD ANYWAY AND INSTALLED THE
ENGINE BACK ON THE TRACTOR, AND ROCKED IT BACK
AND FORTH IN GEAR UNTIL THE ENGINE MOVED.I THEN USED THE STARTER TO CRANK THE ENGINE AND IT WAS
JUST FINE AFTERWARDS.RUNS JUST FINE.
Post A Followup
: Re: Re: New felt Seal, Tight engine on Super A
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
