Re: Engine kit is here!!
Posted by gene b on January 16, 2003 at 05:08:54 from (63.25.167.247):
In Reply to: Engine kit is here!! posted by shaggy on January 14, 2003 at 12:09:11:
Which pistons are you going with? I used a FIRE-CRATER kit and customer realy likes the power as we put a 6-ft WOODS mower he mows several acres pond ect 2nd gear 3/4 throttle. KIT was 430 but was s@p bearings and gaskets. Prices just keep getting higher all the time and they sure do vary according to different suppliers. GOOD LUCK you will need the power when you get my plow.
Post A Followup
: Re: Re: Engine kit is here!!
