Having hydraulic cylinders rebuilt
Posted by Scott(TN) on January 16, 2003 at 06:14:31 from (138.164.194.139):
I am preparing to remove the the 2 hydraulic cylinders on my 400 to have them rebuilt (they leak). Will I need to drain the fluid in the resevior prior to removing the cylinders?
Also, I need to replace the battery box. When I remove the two bolts holding the connection block that is attached to the battery box, will block start to leak?
Thanks in advance for your thoughts!
Post A Followup
: Re: Having hydraulic cylinders rebuilt
