Re: 1466 Hydraulic Problem
Posted by Chuck on January 16, 2003 at 10:14:01 from (216.170.58.10):
In Reply to: 1466 Hydraulic Problem posted by J Duke on January 15, 2003 at 16:44:03:
You say the three point raises at the correct speed,which should be 3 seconds.Is that with an implement mounted or with no weight on hitch.It makes a difference on giving you a correct diagnosis.If the three point is slow with a load on it you have an internal leak.If it raises at the correct speed with a load on it then Mitch is on the right track,your spool in your auxillary valve is not moving far enough to give you full flow to the outlets.Possibly dirt,bird or mouse nest or worn linkage.The fellow that is experiencing load drop and correction several times a minute we call hickups.That is an internal leak,possibly a worn o ring or a pilot valve adjusted to sensitive.
Post A Followup
: Re: Re: 1466 Hydraulic Problem
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
