Re: loader hose hookup
Posted by gene b on January 16, 2003 at 16:43:02 from (63.15.137.234):
In Reply to: loader hose hookup posted by ryan on January 16, 2003 at 16:27:45:
You didnt say whether your cyclinders are single or two way as for the contril valve the IN would be hooked to the small line off the pump as that is the pressure. the large on the pump is the return that is where the out from the controlvalve goes. NOW ARE THE CYCLS SINGLE or TWO-WAY. yOU WILL ALSO HAVE TO HAVE AN AUXILLARY TANK FOR EXTRA HYD OIL THESE USUALLY ARE FASTENED ON THE FILL TAPPED HOLE ON THE LEFT SIDE. A two quart or so tank could be enough depedning on the dia of the cycls and the length also.
Post A Followup
: Re: Re: loader hose hookup
