Re: Re: 1-point disk any good???
Posted by Chad on January 17, 2003 at 12:34:09 from (152.72.252.244):
In Reply to: Re: 1-point disk any good??? posted by Ben in KY on January 17, 2003 at 09:02:09:
the pull behind is just that you pull it behind with no lift. the 1-point we are talking about fits in the the farmall fast hitch. The fast hitch lets you lift your implements with your hyd's.
Chad
Post A Followup
: Re: Re: Re: 1-point disk any good???
