Re: 1466 shifting problem
Posted by Ernot on January 18, 2003 at 18:18:45 from (207.190.67.25):
In Reply to: 1466 shifting problem posted by Joe on January 17, 2003 at 22:09:04:
Before you get to carried away, does the shifting lever have any friction at all. I suspect the roll pin is sheared off on the couplers on to p of th e transmission. If you pull the cover off under the steering column. Its between your feet, right above the deck, between clutch and brake pedals. 2 bolts 9/16 wrench I think. Pull that cover. You'll see the hydraulic lines and two vertical rods. One is for the range, the other for the H & L. Sometimes the pins shear partially off and only let the linkage grab one or the other, the high or low. These stupid pins are like 25 cents, there is two of them.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
