Re: Re: 1466 shifting problem
Posted by scottAR on January 18, 2003 at 19:15:00 from (209.194.159.136):
In Reply to: Re: 1466 shifting problem posted by Bermuda Ken on January 18, 2003 at 05:40:07:
Ken, I've been wanting to ask someone in the know so I'll just ask you. Does any company make a repair sleeve or bushings to tighten the shifting post on the side of the dash of a 66 series tractor? After so many years, installing new levers does not take all the slack out.
Post A Followup
: Re: Re: Re: 1466 shifting problem
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
