Farmall Tractors Discussion Board
Re: 5088 hydralics
Posted by SDman on September 01, 1999 at 21:55:40 from (63.65.237.144):
In Reply to: 5088 hydralics posted by matt hoscheit on September 01, 1999 at 16:48:25:
Matt, you are in the right area with the ball & spring. This is a signal check valve so that the highest system pressure requirement is sent to the compensator. When you replaced the ball & spring, did you look at the seat that the ball fits into? This seat must be perfect, as any leak will bleed off signal pressure to the pump. IH used to have a special tool for "coining the seat" in the valve. Usually, I just tap on the ball with a punch a couple hard times & it seems to work. Good luck!
Post a Followup
: Re: Re: 5088 hydralics
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
