Re: M Trans shifter
Posted by Don LC on January 19, 2003 at 15:08:26 from (24.166.240.210):
In Reply to: M Trans shifter posted by Dan on January 19, 2003 at 14:55:11:
The end of the shaft has wore a bit too short.....If you can tell by looking put a "gob" of weld on the end of the shaft and file and grind it back into the nessary original shape........
Post A Followup
: Re: Re: M Trans shifter
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
