Re: Re: Re: Re: Re: Cubs and other tractors I have owned
Posted by Wardner on January 19, 2003 at 21:26:04 from (64.156.20.36):
In Reply to: Re: Re: Re: Re: Cubs and other tractors I have owned posted by Brown Dirt Cowboy on January 19, 2003 at 18:53:27:
So george, when are you going to build a front wheel assist cub? Place a pinion off the back side of the diferential ring gear and run a drive shaft forward similar to the sickle bar mower. Put a small tranny with neutral under the deck and send the output to a "Cubota" front end.
A cleaner option would be to cut and reinforce an opening on the right side of the transmission near the mainshaft and attach a six bolt truck pto. Might have to find a vocational school with a gear hobber or Hardinge to make you a gear.
I know you can do it.
Post A Followup
: Re: Re: Re: Re: Re: Re: Cubs and other tractors I have owned
