Re: H rear end/trans fluid
Posted by Steven@nd on January 20, 2003 at 17:17:19 from (12.23.184.2):
In Reply to: H rear end/trans fluid posted by Nick in SC on January 20, 2003 at 16:14:25:
Do not use HyTran in your rearend! The bearings won't get the proper amount of lubrication. These tractors were designed for heavy weight gear lube. HyTran will probably work, but when you push the clutch the gears will keep going and going and going and you will have to grind it into gear.
I use 85W-140 gear lube in my H and it slides into gear right away with no grinding. 90 weight will work too. And it holds 6 gallons.
Post A Followup
: Re: Re: H rear end/trans fluid
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
