Re: dent in gas tank
Posted by Roger on January 21, 2003 at 19:38:37 from (209.100.170.89):
In Reply to: dent in gas tank posted by rob on January 20, 2003 at 20:11:04:
I have tried several methods to get dents out of tractor gas tanks. I tried the body shop suction cups, but the tractor gas tanks are made of much heavier sheetmetal than car fenders. I am working on a B Farmall with dents in the gas tank. I am thinking of trying the paintless dent method. They glue a block to the center of the dent and use a bridge across the dent and pull up on the glued down block with a threaded rod. I still don't know if you can get enough force without pulling the glued block off the metal. I am going to try it when it warms up so I can get the paint off and pull on the bare metal. If that doesn't work it's bondo. Someone mentioned using air pressure. If you pressurize the tank you will end up bulging out the bottom of tank as those tanks were never meant to be pressurized to say nothing of the safety hazard (I don't think a tractor fuel tank would stand 40 psi without blowing up - at least most of them) Roger
Post A Followup
: Re: Re: dent in gas tank
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
