Re: Up date on H steering problem
Posted by Matt K. on January 22, 2003 at 06:50:27 from (204.23.231.133):
In Reply to: Up date on H steering problem posted by Farmall Ed on January 22, 2003 at 06:12:12:
Ed,I had to jack the front end up on mine and
tap on it with a oak block,this was after it had
been soaked with PB-blaster for a couple of days.
I made sure the nut was part way on and kept
tapping the shaft and it finally popped loose.
I think the weight of the front wheels pulling
down on it may have helped out.
Good luck ,Matt
Post A Followup
: Re: Re: Up date on H steering problem
