Re: m farmall hydraulics
Posted by Peabody on January 22, 2003 at 07:26:48 from (66.168.244.101):
In Reply to: m farmall hydraulics posted by randy grider on January 21, 2003 at 13:11:05:
Several years ago, I helped a friend R&R a belly pump on his M. We had the same problem, hydraulics would lift but not release. After removing and inspecting the pump several times, I finally realized he had installed the large valve needle(s) upside down in the pump. They fit fine that way, but could not release pressure.
If your pump was overhauled along with the engine, that could be a possibility. Good luck.
Post A Followup
: Re: Re: m farmall hydraulics
