Re: Re: Re: H Head Stud washers?
Posted by KBBob on January 22, 2003 at 08:29:31 from (205.188.209.78):
In Reply to: Re: Re: H Head Stud washers? posted by Bob inSE Nebraska on January 22, 2003 at 05:23:28:
it looks as if there are tubes or pipes pressed in the head where the washers are used. Years ago I worked with a IH tractor mechanic, he would use a tapered punch and lightly drive it into those tubes from the head gasket side making sure they were tight and sealed the top side where the washers were used with white lead. Maybe a possibility of lube oil getting into coolant or coolant into the oil?
Post A Followup
: Re: Re: Re: Re: H Head Stud washers?
