Farmall Tractors Discussion Board
Re: Re: Re: Why the disagreement on placement of resistor???
Posted by LarryG on September 02, 1999 at 11:30:55 from (198.64.254.11):
In Reply to: Re: Re: Why the disagreement on placement of resistor??? posted by Corky on September 02, 1999 at 10:36:24:
I'd like to disagree that it matters on the placement of the resister. The object is not to have more than 6 volt drop across the coil to prevent excessive current and therefore, heat. It doesn't matter whether it is 6 to 0 volts, 9 to 3 volts, 12 to 6 volts, or 100 to 94 volts (assuming the insulation in the coil could handle 100 volts to a grounding potential (voltage) of 0 volts. It's a simple DC series circuit, E=IR.
Post a Followup
: Re: Re: Re: Re: Why the disagreement on placement of resistor???
