Re: C to Super C
Posted by Haas on January 23, 2003 at 04:03:12 from (166.72.245.39):
In Reply to: C to Super C posted by ryan schmit on January 22, 2003 at 17:28:13:
The water pump will fit, but you don't need it. While you have the front off, take off the water elbows on the head and the block and blow out the block and head passages with water and air. Have the radiator cleaned at a shop and you should be good to go. I used my C last year on some heavy work (for it) in 90 degree temps. It has no water pump and never got hot. I grew up on these tractors, and I guess the biggest problem is if you let the coolant get low which can happen due to evaporation, especially in non pressurized systems (most Cs have a pressure cap). If the coolant gets low, first thing that happens is you burn the exhaust valve on No. 4 cylinder. Of course low coolant will cause trouble in any system.
Post A Followup
: Re: Re: C to Super C
