Farmall Tractors Discussion Board
Re: Re: dipstick to check hydraulic fluid
Posted by larry on September 02, 1999 at 12:29:48 from (147.253.19.27):
In Reply to: Re: dipstick to check hydraulic fluid posted by big fred on September 02, 1999 at 12:20:47:
thanks for the help fred as i found it just like
you said the dipstick was indeed on the plug
thanks again for the help
Post a Followup
: Re: Re: Re: dipstick to check hydraulic fluid
