Re: Re: Going through the M?? $$$?
Posted by Bill Smith on January 25, 2003 at 11:02:47 from (63.147.130.33):
In Reply to: Re: Going through the M?? $$$? posted by Steve450 on January 24, 2003 at 14:11:49:
You said that I had to remove the block to do the rear main. Was you refering to the seal or the bearing. No real big deal if I couldn't replace the seal (I was figuring on not being able to do that with out splitting) but would really like to put a new rear main bearing in.
Post A Followup
: Re: Re: Re: Going through the M?? $$$?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
