Re: Shop heat
Posted by BIG JOHN on January 25, 2003 at 18:40:33 from (205.188.209.78):
In Reply to: Shop heat posted by Farmsome on January 25, 2003 at 10:11:57:
Just moved into my new shop. I installed a 100,000 BTU propane radiant hanging heater. It is about the size of a florescent light fixture. Works great, burns about a gallon of propane an hour. Only draw back is that you need good clearances from any combustable, so it might not work in every case.
Yesterday it was -11 degrees. Took about 20 minutes to warm up enough to work is just shirt sleeves. Heats the objects not the air.
Post A Followup
: Re: Re: Shop heat
