Re: IH656 Utility good or bad?
Posted by bill o on January 26, 2003 at 09:01:10 from (208.171.51.244):
In Reply to: IH656 Utility good or bad? posted by Steve on January 25, 2003 at 19:47:30:
check the front end axle pin on a 656 utility. the axle and knees are the weak point on the utility, especially if it has had a loader on it. i have a farmall and an international 656, both gas and both hydros. we use them for loading and feeding. they work great, and they start in the cold. i also have an 826 hydro for bigger harvesting work. check the hydro for slippage, as noted above. the hydros are much easier to use on everything but bull work (tillage, etc).
Post A Followup
: Re: Re: IH656 Utility good or bad?
