Re: Shifting Problem
Posted by hpuller on January 26, 2003 at 17:42:04 from (12.36.212.1):
In Reply to: Shifting Problem posted by Brad T on January 26, 2003 at 09:34:57:
You might check the clutch disk. It might be worn down far enough it wont release the transmission. My H was doing something similar to yours and that is what I found. My clutch disk was wore down to the rivets.
Post A Followup
: Re: Re: Shifting Problem
