Re: Farmall plow question
Posted by bill o on January 27, 2003 at 17:53:39 from (208.171.51.161):
In Reply to: Farmall plow question posted by Gary- The Rookie Farmer on January 27, 2003 at 07:44:06:
if your h has hydraulics, you will be much happier with a hydraulic lift plow. if no hydraulics, you'll have to use a wheel lift type plow. if you'll be plowing in rocky ground, some type of trip or spring release on the plow will save some possible damage when you hit a buried rock. colters will help much when plowing sod. pick a brand that has parts available at reasonable prices. that likely means ih or jd. either one should work ok with an h.
Post A Followup
: Re: Re: Farmall plow question
