Re: 300 Charging problem
Posted by Bob M on January 28, 2003 at 15:45:42 from (66.66.123.133):
In Reply to: 300 Charging problem posted by Dale Hickl on January 28, 2003 at 13:28:08:
Dale - 17 volts open circuit is excessivly high for a 6 volt generator, especially at idle with no wiring connected. That, and the blue paint, makes it sound like you've got a Ford 12 volt generator there. (Check it over for Ford or FoMoCo markings). If it is you need to find and wire up the Ford regulator for that specific generator for it to work properly. Or swap out the existing generator for the correct IHC/Delco generator. To your other questions: Generator polarity is not an inherent generator feature. It's determined only by the polarity of the grounded battery terminal when the generator is "polarized" on the engine. Once a generator is polarized it won't change polarity unless it is disassembled, or something catastrophic - like being struck by lightning - happens. And regulators - at least regulators for systems built thru the late 50's - are not polarity sensitive. They will function fine either positive or negative ground. Once again polarity is determined when you polarize the generator.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
