Fluid Change on a 1086
Posted by Jack S. on January 29, 2003 at 07:31:35 from (64.12.97.13):
I have just come across a IH 1086 and I would like to change the Hy/tran fluid. I see from the manual that it take 90 guarts. I am not sure about which drain plugs need to be removed. Are they the center plug and two side plugs under the rear axle carrier? Plus the PTO drain plug and is there a clutch housing drain plug? Thanks for your help, just want to be sure that I get all the old fluid out.
Post A Followup
: Re: Fluid Change on a 1086
