Re: Re: 300 Charging problem
Posted by d hickl on January 29, 2003 at 10:05:45 from (64.154.26.248):
In Reply to: Re: 300 Charging problem posted by gene b on January 28, 2003 at 18:58:18:
Gene- the voltmeter is ok. The field may be shorted internally as Bob mentioned causing full output. The voltage will climb well past 20 with throttle. This thing has been tinkered with over the years by countless people so who knows. The tractor requires so little electrical energy to run that it will go for hours on battery alone.
Its one of those deals where someone probably swapped it to neg ground not knowing any better, then the next guy (relative) changes regulators and so on. Thanks for the reply!
Post A Followup
: Re: Re: Re: 300 Charging problem
