Re: Re: Re: Rookie screwed up already
Posted by Bob M on January 29, 2003 at 10:31:49 from (165.170.128.66):
In Reply to: Re: Re: Rookie screwed up already posted by Gary- The Rookie Farmer on January 29, 2003 at 09:08:37:
If the battery is up and all the wiring is good, a click but no crank will also indicate the starter pinion is stuck in the flywheel ring gear (A common occurrance in Farmalls with worn starters and ring gears). If the tractor is on hard ground, put the transmission in 5th gear and try rocking it back and forth a bit (make sure the ignition is OFF!!). If you hear a clunk and see the fan move at all, you've unjammed it. If you cannot rock the tractor, simply loosen several turns the (3) capscrews holding the starter to the flywheel housing, then pull back on the starter. If the pinion is jammed you will feel/hear when it disengages. Finally tighten the screws back up and try the starter again.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
