Re: What does Bad TA mean?
Posted by it depends on January 30, 2003 at 07:21:56 from (165.170.128.68):
In Reply to: What does Bad TA mean? posted by BillWV on January 30, 2003 at 07:08:30:
"Bad TA" can mean a couple things. If just the low side is out, the tractor will still run and can be used normally in direct (high) range. It just won't go if you shift the TA into low. This seems to be the more frequent failure mode. However if the TA has failed completely (both low and direct are out) you are dead in the water!
Post A Followup
: Re: Re: What does Bad TA mean?
