Farmall Tractors Discussion Board
Changing Rims On the H-Thanks for the Tips Red
Posted by Greg M on September 03, 1999 at 23:01:12 from (216.192.41.48):
I reversed the rims on the H last weekend. Since the tires are water filled they are very heavy and I don't have anyone around to help out. However, based on The Red's advice I was able to take the tire and rim off of the hub, remove the hub, reverse it (from concave side in to concave side out) and then get the tire and rim back on in about 45 minutes. The tip I used in putting the tire and rim assembly back on was to put it on the hub and then jack the tractor up until the whole thing swung back in place. Worked like a charm. Thanks for the tip, Red. It saved me a lot of head scratchin' and heavy liftin'.
Post a Followup
: Re: Changing Rims On the H-Thanks for the Tips Red
