SMTA Hyd Reservoir ?
Posted by Dave in MN on January 30, 2003 at 10:43:44 from (152.163.189.203):
All I wanted to do was replace a tiny little O ring in the reservoir to stop my little Exxon Valdez from running Hyd Fluid out the control lever. I got the O ring replaced. Now, I can't get the darn cover back on. There is a shaft on the control lever that must fit into the piston valve lever while the high pressure tube must fit into its slot. Tube goes in fine, but the shaft just will not slide into the piston lever. Anyone out there ever gotten one of these back together?
Thanks in advance!
Post A Followup
: Re: SMTA Hyd Reservoir ?
