Farmall Tractors Discussion Board
Re: Wiring an H to start
Posted by The Red. Here we go on September 04, 1999 at 05:26:31 from (12.75.196.29):
In Reply to: Wiring an H to start posted by Pat on September 04, 1999 at 05:17:22:
Pat this is simple a get the durn thing started settup.
Battery cable wise its a positive ground. Hook the negative post to the cable that goes to the starter switch then of course the cable goes from the starter switch to the starter. Cables should be 1 gauge.
For the coil hook up, run a 10 or 12 gauge wire from the hot side of the starter switch to the coil switch. Then from the coil switch to the negative post on the coil. Then a wire from the positive post of the coil to the distributor.
This won't work your lights or charge but it will at least enable you to see if it will start.
Email me with any further questions if you would like.
Post a Followup
: Re: Re: Wiring an H to start
