Re: Re: Re: Rebuilding an engine
Posted by K.B. on February 01, 2003 at 11:18:26 from (209.163.43.92):
In Reply to: Re: Re: Rebuilding an engine posted by Tim Malin on February 01, 2003 at 11:03:57:
"Pushrod" means that the valvetrain is in OHV (overhead valve) configuration. The camshaft is located inside the engine block and opens the valves by pushing up on the lifters, which push up on the pushrods, which move the rocker arms, which open the valves, just like any IH tractor engine. Nowadays, the industry is going to OHC (overhead cam) in which the camshaft is located in the cylinder head. Most cars have overhead cams, and even a few tractors do too.
Post A Followup
: Re: Re: Re: Re: Rebuilding an engine
