Re: Farmall 200 +/- ground??
Posted by Bob M on February 02, 2003 at 07:11:44 from (66.66.123.133):
In Reply to: Farmall 200 +/- ground?? posted by Deamer on February 02, 2003 at 06:18:44:
Deamer - It's fine to run the tractor the way it is (negative ground) so long as it charges the battery OK. However if you want to switch back to positive ground all you need do is swap the wiring at the two ammeter connections, then repolarize the generator after you connect the battery. (To polarize, momentarily connect the BAT and GEN terminals at the regulator with a short jumper wire with the motor stopped.)
Post A Followup
: Re: Re: Farmall 200 +/- ground??
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
