Re: To Rebuild or Not?
Posted by Shovelman on February 02, 2003 at 09:58:09 from (24.151.89.245):
In Reply to: To Rebuild or Not? posted by Dave in MN on February 01, 2003 at 22:02:48:
Dave,
Of course, it it entirely your call, but why rebuild if it doesn't need it? Does it really matter when it was rebuilt last? If it runs well and you have carefully checked it out, save your money and put it to good use, like another tractor.
Do a compression test, run it hard and check operating temp., oil pressure, noises, leaks, etc., then decide if it really needs overhaul.
As you probably know, rebuilds are expensive and I agree with Hugh that once you start, you have to be prepared to go all the way.
I just finished an overhaul on a 1650 Oliver yesterday. $1800 in parts and $650 in machine work. It can get expensive in a hurry. Believe me, I wouldn't have done it if it had ran well.
It doesn't sound like you are going to ever subject the tractor to severe service, nor does it sound like you are depending on it for your living. I would take that into consideration if the engine checks out O.K.
Good luck!
Scott
Post A Followup
: Re: Re: To Rebuild or Not?
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
