Re: HELP w/Hydraulics PLEASE
Posted by HD on February 02, 2003 at 10:11:00 from (216.74.198.125):
In Reply to: HELP w/Hydraulics PLEASE posted by Stumped 460 Utility on February 02, 2003 at 08:25:57:
I don't have a utility but think the Farmall 460 will be the same. Look at the lowest point on the rear end housing and you will see a big plug. This will drain the Hi Tran fluid for the trans and the hyd. system. To refill there will be a check plug over on the left side forward of the foot clutch and has a small hex plug inside the bigger plug. This hex is the check plug. Do not remove the bigger plug. In front og the steering colum there will be a flat plate with maybe up to 10 screws holding it on and I have been refilling there as it is easier to get access to. Be sure to do a good resealing this plate when reimstalling.
Post A Followup
: Re: Re: HELP w/Hydraulics PLEASE
