Re: Regular
Posted by Rob Myhren on March 29, 2009 at 07:03:57 from (208.33.229.19):
In Reply to: Regular posted by kennebunksawmill on March 29, 2009 at 06:06:26:
My F-12 is hand start and my f-20 is electric. The both of them are pretty much the same to start. Make sure you set the mag, turn on the gas, set the throttle, MAKE SURE IT IS IN NEUTRAL if its hand crank, give er alittle choke and should start. How long have the tractors been sitting?? Make sure you check the oil level and coolant/water also.
