Re: Farmall Super A spark plugs and carburetor adjustment
Posted by Dave, Sherburne, NY on February 02, 2003 at 18:38:53 from (216.238.58.130):
In Reply to: Farmall Super A spark plugs and carburetor adjustment posted by Dave on February 02, 2003 at 17:28:02:
I&T manual says Champion 15A
A C 85S
Autolite BT8
I run AC C86 in mine and bad plugs could
be the cause of your problems
As far as carb adjustments go , big one on the
bottom is the main jet I would start at about
1 and 1/4 turns out , and the idle screw on
the top, 1 turn. PUT new plugs in it before
you try anything . Not sure about adjustments
My tractor is out in the garage along with
the operator's manual and its + 4 degrees
out there. This is for a MarvelShebler carb
Book says you could have a Carter or Zenith
too
Post A Followup
: Re: Re: Farmall Super A spark plugs and carburetor adjustment
