Re: Re: Re: Hydraulic Fluid in Oil Pan
Posted by Bob M on February 03, 2003 at 06:15:55 from (165.170.128.68):
In Reply to: Re: Re: Hydraulic Fluid in Oil Pan posted by Andy in MN on February 03, 2003 at 05:34:34:
Andy - To set to TDC first mark the outside of the distributor housing where the #1 plug tower is the dist cap. Then remove the distributor cap, but leave the rotor button in place. Now "bump" the starter while watching the distributor rotor. Stop when the rotor terminal nears the mark you made on the dist housing. Finally grab the fan blade and use it to manually turn the engine the last bit to TDC - indicated when the pointer on the timing gear cover lines up with a notch mark on the crank pully. (Sometimes it helps to remove the spark plugs for this step...)
Now if you don't disturb the crankshaft with the hyd pump removed, all you need do is make sure the distributor rotor lines up with the mark on the housing when the hyd pump/distributor are back in place.
Post A Followup
: Re: Re: Re: Re: Hydraulic Fluid in Oil Pan
