Re: Farmall Super A spark plugs and carburetor adjustment
Posted by Dave, Sherburne, NY on February 03, 2003 at 08:12:22 from (216.238.58.155):
In Reply to: Farmall Super A spark plugs and carburetor adjustment posted by Dave on February 02, 2003 at 17:28:02:
Got the manual here this morning On the carter, the main jet is on the end on the top of
the carb doesn't give a default setting , For
the idle, default is 1 turn. Doesn't give any
default for Zenith . Spark plugs as I stated
last night. Pull the plug out of the bottom
of the carb, to make sure you have a good flow.
Spark plug gap is .023 to .027.
Post A Followup
: Re: Re: Farmall Super A spark plugs and carburetor adjustment
