Re: 424 steering
Posted by Gary on February 03, 2003 at 17:57:42 from (64.12.103.33):
In Reply to: 424 steering posted by dean on January 29, 2003 at 16:43:18:
First thingsfirst, jack up thewhole front end, then grease the spindles. It follows the path of least resistance and will not grease the thrust bearings on the bottom of the spindles unless the weight is off. While it is up, check to make certain the shaft that travels next to your block is not rubbing. Check and refill the steering sector with trans grease.
Post A Followup
: Re: Re: 424 steering
