M wide front
Posted by ScottCT on February 04, 2003 at 06:23:46 from (149.152.23.8):
I recently purchased a wide frt farmall M. The engine is a basket case, but the rest is near perfect, even the PTO shield and lights are still there and straight. Even has good rubber, loaded in the rear. About what would this tractor be worth running (straight tin)? I might think about selling in the spring. Thanks in advance.
Also, where is the serial tag located?
Post A Followup
: Re: M wide front
