Re: Re: Re: Re: Re: need some help with cultivators
Posted by Larry in CO on February 04, 2003 at 15:35:22 from (32.97.110.142):
In Reply to: Re: Re: Re: Re: need some help with cultivators posted by will on February 04, 2003 at 14:38:10:
Will, There are more differences in the H and SH than just 2 horsepower. Here is a copy of a post that STEVEN@ND posted back in August 2002 relating these differences. Thanks Larry "H: 152 cubic inches - Super H: 164 cubic inches H: 5.9:1 compression ratio - Super H: 6.1:1 comp Super H had improved combustion chambers on the head, rounded with tops slanting away from the spark plug - this reduced "pinging." Also the Super H had exhaust valve rotators while the H did not. Super H camshaft held the intake valves open longer. Crankshaft was beefed up, larger diameter main and rod journals. Aluminum pistons came in the Super H along with other improvements on the pistons. Air intake from carb was increased in size, larger exhaust ports were also utilized. Carb was increased from 1 inch to 1 1/4 inches on the Super. Super H had an all new clutch that was 10 1/2 inches instead of the 10 inch on the H. New clutch facing material had copper wire to increase the life; radial grooves reduced grabbing and smoothed the release. In the transmission there were more pilot bearings and the gears were widened and induction-hardened. Speeds were also slightly changed. Rear axle and differential had better bearings with more capacity, and of course the disc brakes. The Super H's with live hydralics had a different front cover and beefed up timing gears, also the battery was relocated to under the seat. Above info comes from Guy Fay's book "Farmall Letter Series Tractors" In short, the Super H is NOT an H with a bigger engine, it was a whole new machine."
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
