Posted by Bigdog on March 29, 2009 at 07:26:07 from (71.64.18.18):
In Reply to: Timing a Cub engine posted by Klein Rot on March 29, 2009 at 01:37:07:
With a mag you should have only one mark on the pulley which is TDC. If you have two marks the second mark is TDC. That is the one you use to set the static timing. Once you get above about 400-500 rpm the mag will advance but it is a fixed advance so if you set the static time the advanced time will be correct. The timing procedure for the mag is in the operator's manual.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
