Re: Moved H today, Bad news
Posted by Ludwig on February 07, 2003 at 08:35:20 from (141.154.116.114):
In Reply to: Moved H today, Bad news posted by Robert in Md. on February 06, 2003 at 20:04:21:
Big rollback huh? I dragged my Regular out of its resting place with the Super M and it took everything the Super M had to do it. I wouldn't have wanted to try it with a smaller tractor!
Anyway the Regular has a very simple brake system which is okay since it only goes 4mph, but I was amazed at how tight it was stuck. It took alot of heat and beating to get it unstuck.
In other words I doubt that too much was likely to get broke because the brake being stuck would absorb most of the force.
Now you might have to do some bearings in there, but you probably would have anyway...
Good luck!
Post A Followup
: Re: Re: Moved H today, Bad news
